configure identity-management role delete child-role
configure identity-management role role_name delete child-role [child_role | all]
Description
Deletes one or all child roles from the specified role.
Syntax Description
role_name
Specifies the name of an existing role.
child-role
Specifies a name for a child role to delete.
all
Specifies that all child roles are to be deleted.
Default
N/A.
Usage Guidelines
None.
The following example deletes the child role named East from the existing role named India-Engr:
* Switch.66 # configure identity-management role "India-Engr" delete child-role East
The following command deletes all child roles from the existing role named India-Engr:
* Switch.66 # configure identity-management role "India-Engr" delete child-role all
This command was first available in ExtremeXOS 12.5.
The all option was added in ExtremeXOS 12.6.
Platform Availability
